Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
The tray instructions show replacing floorboards with a piece of plywood.
Is really necessary to remove the floorboards and replace with a plywood base?
It would be less fuss to just place a plywood base on top of the floorboards and then I would not need extra carpentry, i.e. noggins. Surely.
Cutting those flooboards creates a need for new supports. Leave the floorboards alone, and just put the plywood sheet down - ought to be okay?
Or, put the plywood down covering two joist spaces rather than one and a bit. But, my preference is just to put a plywood base on top of the floorboards. If that is okay, I'd do that.
I assume they are nice thick seasoned pine boards 18mm+? Nope, no need to remove them IMO. Also replace the ones you have lifted if you have them.
Nice thick exterior structural or Marine ply going down? Make sure it's from a reputable supplier and stamped as such, some structural ply isn't exterior therefore water resistant but there's a lot of it that's been marked as such due to the prices difference.
