Floor screed leveler
21 Apr 2007
Surrey
I have a situation where the whole of the ground floor of the property has a tiled surface, with rooms created by stud walling. On re positioning some of the stud walls we have found that the tiles do not pass underneath and there is therefor a chanel of where the old walls used to be. I am not immediately able to find matching tiles but I want to make the floor surface safe. I thought of using a liquid self levelling screed. My question is would I be able to lift and remove the screed, simply, in a couple of months when I am ready to tackle the tiling or will it set off so hard that I would not be able to remove it. ? The area is about 20' run 6" wide plus about 1 square yard where a shower tray was removed.
RogHold
use a latex screed as its weak with no primer. also add a cup full of water to it. This will make it weaker still.
