floor un-even!!!!
15 Oct 2007
Humberside
just screwed new ply down on to existing floor boards in the bathroom and started marking out ready to tile but found out one side of the room is 50mm lower than the other side
can i just use more adesive on the low end to build it up?
also the existing shower try is is sat on the floor boards so it is also falling and there supposed to be level arnt they?
anyway its falling towards the drain so the water will get away but should i take it out and re-level it or should it be ok?
thanks for any advice any1 can give me
No
Yes
Yes
or should it be ok?
No
so im f**ked then?
any1 got any ideas?
why does it matter if shower tray isnt level if its fallong towards the drain?
ill have to rip ply up anyway, builders merchant told me to pva it which ive done but ive just read on here that you shouldnt and that the tiles will fall off so again im f**ked
The tray should be level, you'll have a hell of a job trying to bit the enlosure if its not. Are you fitting the tray directly onto the floorboards/ply? If so have you got room for the waste? I sat my tray up on a plinth to give me room underneath for the waste - if you did the same you could make the plinth in such a way that you took to uneveness out of the floor.
hi thanks for the reply
my shower isnt an enclosure its just a tray with 2 stud walls, there isnt even a door i have to use a curtain becouse of my sloping roof
Ideally it still should be fitted to a level surface but if thats not an option at least make sure the surface you are fitting to is completely flat and that the tray is fixed and supported evenly.
