Ok.... moved into a new house recently and one of the first things I want to do is floor part of the loft space for light storage items such as suitcases etc.
The insulation that has been installed by the house builder is about 300mm deep. The height of the insulation does go above the trusses by about 150mm max.
I fancy taking this project on myself, but need to seek some advice first to help work out the best way to approach it. I plan to use tongue and groove material as the main flooring medium.
My thoughts are... if I pressed the tongue and groove directly onto the trusses which would then give the insulation a downward force, would this cause the ceilings below to 'swell'?
Or, do I need to raise the floor above the insulation which would still allow plenty ventilation underneath and would also eliminate the pressure of insulation on the ceiling plaster board?
If the right approach is the latter idea, what is the best way to go about it?
My Collins DIY manual doesnt seem to cover this.
