Flooring around a low profile shower base.
14 Aug 2011
Gloucestershire
We're fitting a low profile, stone resin shower base, which will be cemented to 18mm ply. The rest of the floor is tongue and groove. My question is really about how to put down the flooring around the base. We want to put down bathroom laminate, but don't know how to tackle the interface between the base and the flooring. I don't want to spoil the look of it by siliconing pvc strip around it, so wondered if it is ok to not cement the very edge of the base and slide the laminate under.
Cheers.
I'd forget the laminate mate, water from the shower will eventually lift it.
If you can put down 6mm plywood and some wood fx polysafe or LVTs like Karndean or ployflor camaro.
Thanks for the advise Dazlight, but can you tell me if I can slide the flooring (whatever that may be) under the edge of the shower base?
Cheers.
I have done before mate as long as the shower base is solid. When you set it in leave it 8mm high so the ply and vinyl can go under
