Flooring brads
16 Jun 2006
London
Hi all.
One of my customers had their exposed floorboards lifted by their builders. They now have a number that squeak when you walk on them. On closer inspection the squeaks seem to come from the original holes where the brads are. The brads seem to be tight in the flooring joists, but loose in the boards. Would punching the brads lower help?
If not, and I lift each of the boards (slightly), to remove the existing brads, is is possible to purchase ones which are the same length but slightly "fatter", possibly with a bigger head?
I won't be back on that site until next week but from memory, they were approximately an inch and a half long (possibly a tad longer).
Oh, and if punching them deeper will help, what king of punch can you use? I only have round punches (various sizes).
Thanks.
I cant use screws. When I said the boards are exposed, I meant they are stained/varnished and not covered with carpet.
Bigger screws with pellets to hide the heads?
I had thought about that but that would require me to every plank in a 3 story house. At the moment only 20? boards are squeaking.
Perhaps I need pellets with the brad head inserted to maintain a uniform finish...
In all seriousness though, that would require me to sand the area where the plugs/pellets are which will cut through the wood stain.
Thanks anyway.
One skewed to the left, the other to the right. Only needs to be 5 to 10° off vertical tobe effective. Sometimes called "dovetail nailing"
Can't get hold of a 15 ga nailer? Buy a rampin (probably need to go secondhand as these are old technology) and use that to drive in panel pins. Finish with a hammer and appropriate size nail set
I only have 18ga nailers. Can't I just drill a pilot hole to offset the nails? I don't have a massive amount to do.
Yes, that works - it's just tedious if you have many. The rampin suggestion was if you had loads to do.
