Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
can be done. use a 3A fusein the plug and flex, not T+E. make sure you put a grommet where the cable enters the fitting, or a gland would be better if itll be moved often
so long as you use 3 core flex, the flex is secured inside the light, earth is connected at both ends (plug and light) and you put a 3 amp fuse in the plug then yes it will work.
How ever a flourescent by its nature is dangerous as they dont half go bang and make a mess when they fall over. if you are going to permanently fix the light use 1.mm twin and earth and fit a FCU
what is wrong with using plugs and sockets for this kind on a permanent or semi permanent basis?
and if there is anything wrong with it how is it any different from plugging them into those klick sockets where are used all the time on commercial installs?
i dont see a problem with using a plug. 1/2 of my room (4 double sockets) was all connected to a plug for over 1 year (i then put a SFCU nxt to the socket for it)
I can think of a very good reason for putting a plug on a fluorescent light fitting. You want to fix it under your kitchen wall units and of course you don't have a spare FCU handy. To make things worse you've just had the walls tiled at considerable expense. It's plug time!
