just to throw a spanner in the works , if you dont have room in the cylinder cupboard for the pump, you can get a wall mounted shower with the pump inside the actual shower as opposed to an external pump
One of these would be a neat choice, up to 14LPM (power shower performance) it has its own integral pump, just supply it with gravity fed hot&cold water. A 9.5kw electric shower will give ~ 4LPM in winter & ~ 5.5LPM in summer.just to throw a spanner in the works , if you dont have room in the cylinder cupboard for the pump, you can get a wall mounted shower with the pump inside the actual shower as opposed to an external pump
You need to check the existing circuit ,that supplied the old electric shower, it may need to be upgraded in order to run a 10.8 kw shower ( thicker cable / breaker etc)
