Flue Boost 100
12 Jun 2008
Dorset
Hi there.
Can you buy the printed circuit board for a Flue Boost 100 on its own?????
If so, can you direct me to someone who sells them.
Many Thanks
yes you can buy the board direct from them but they are 250 pound mine just went off few weeks ago and it seems it looses power to one of the relays so i linked a wire from thermostat wiring inside control unit to the pin on the relay and it works as it should
What does it do that needs a pcb?
Or is that just to mount the motor start relays?
It has a time delay and a saftey interlock circuit.
Fan Starts, vacume sensor see's a pressure drop in the flue, waits 30 secs and then sends power to the boiler.
