Had some fluidmaster dual-flush kits installed a few months ago. Two are fine, but the third has a problem.
If we don't flush it for a number of hours (and, as it's in the en-suite, this tends to happen), it will suddenly start filling for a few seconds, and then stop.
I know this indicates that there is a leak somewhere. Looks like it isn't leaking from the seals, so I'm assuming that the flush valve has a minor leak.
Talking to the technical support at Fluidmaster, the suggestion was to loosen a screw on the button assembly, to reduce the tension on the cable.
Has anyone else experienced this problem, and is the above suggestion successful ?
