Fluke T130 has display issues
30 Mar 2015
I've owned this for less than two years and probably used it half a dozen times but when I went to use it today, the display was misbehaving...
When measuring voltage, it would activate the "Hold" function and switch on the light and then not allow me to switch either of these off. It would on occasions, show no voltage reading on display but the 230v indicator is clearly lit.
I have replaced the batteries and will also be contacting Fluke as I believe that I have a two year warranty. The auto-test also completes successfully each time. Is this a known issue and does anyone have any suggestions?
Also, I assume the voltage indicators are always the accurate indicators of voltage.
Thanks in advance.
Mine was replaced under the recall scheme and the new one sent also failed with the same problem as yours.
Replaced immediately with no questions, can't fault customer care.
Blup
UPDATE: Fluke replaced my tester with a new one and advised me that this has a further 3 year warranty. I used it over the weekend and all seems well again.
Thanks for your help.
