I am in the process of building a timber light box for viewing film on. I am following some plans that require the use of two fluorescent tubes. Lacking knowledge in electrics I have purchased two complete fittings. To these I have attached a lead and plug. However in the instructions for the fitting its says they are not suitable for attaching leads. The leads I have used are with an earth wire. However, here in Denmark not many homes or appliaces have plugs/leads with an earth. I can plug them into the power point but the earth is basically redundant as there is just a hole and no wire in the power point. I have been told that this is ok as we have a safety circuit breaker installed in the house. Is this the case?
Further to this I was thinking of removing the fluorescent tubes from their metal fittings and fastening them and the ballast/starter etc inside the light box (timber) in order to reduce its overall weight. However upon closer inspection of the fittings I see that the earth is actually attached to the metal fitting itself. Given that in my current situation I cannot use the earth is it possible/safe to do this?
Thanks in advance for any help you can offer.
