Hi. I'm trying to recondition my CH a little. Just moved into new house and needs inhibitor etc as hasn't been put in for years as far as I can tell. I was going to put some sentinel x400 in first via a dedicated radiator point. My question is when I come to remove the x400, can I just put a hose on the drain point and run the pump with the drain open - using the heat pump to 'flush' without introducing air into the system (indirect by the way). Or could I drain a little, close the drain, run the pump, open again - relying on the header tank to refill between drains? I'm not really keen on draining the whole system as its a little complex and bound to get air somewhere I cant find.
Thanks for the help
Thanks for the help
