Flushing A Single Radiator
30 Jun 2007
Newcastle upon Tyne
I recently had a new Combi Boiler fitted professionally and the system flushed according to the manufacturers instructions. The fitter also put in some new pipework for a new Radiator I had not yet purchased. Weeks later I fitted the new Radiator, a Vertirad. After a short period of use, the Radiator developed a pinhole leak. B&Q who supplied the Radiator were reluctant to exchange it as they said it had not been flushed (but eventually they did). I don't recall seeing that requirement in the fitting instructions, but if I must, can I flush the single radiator instead of the hassle (and cost) of flushing the whole system again? And if so...How?
Thanks for any help you can give.
you can always flush it out with a hose in the garden before you install it
maybe ive read this wrong.
the system was flushed for the new boiler and pipework added for an extra rad. the new rad subsequently failed?
is the water in the system still dirty? there should be no real reason for clean and inhibited water to kill a rad that quick.
the new rad doesnt need flushing on its own to add to the system. but if the system water is still dirty then you should get it flushed again. bear in mind flushing wont get rid of everything.
They only supply seconds don't they? (allegedly!).
I have to agree with nickso's answer though :wink:
I wonder how much rubbish (oil, grease, iron filings, dog ends, mars bar wrappers etc) the manufacturers leave inside radiators that end up bunging up the rest of your system when you fit a new rad?
