Hi Guys, looking for some advice
I have a cold roof constructed flat roofed dormer that I need to insulate after ripping down the existing ceiling and finding no insulation present.
There is so much choice of insulation available and then there is concern around vapour control.
I have measured the depth of the rafters and they vary between 200mm and 170mm, but the biggest problem is that they are not the same width along, 400mm at majority of places but narrowing down between 300 - 330mm at certain points were whoever constructed the roof used additional support, plus there are nails are all sorts of different pieces protruding along the length of the rafter.
So inserting the celotex type insulation could be quite difficult as it would be difficult to tight fit it along the full length of the rafter and would involve alot of cutting around these narrowing points.
This weekend in a moment of madness I have ordered superquilt foil insulation with the intention of stapling to underneath the rafters and not bothering between the rafters.
There seems to be plenty of ventilation below the ply deck and there will be up to 200mm of ventilation space above the foil and below the deck.
So after stapling the foil to the rafters and taping the joins I will then be screwing 2x2 timbers to the rafters to level the ceiling and to allow a 50mm gap below the foil as per man instructions.
Then finally finishing off with foil backed plasterboard and skim finish.
Concerns:
Will it work? Have I done enough to stop moisture getting to the ply deck and rafters.
Foil insulation seems to be recommended for pitch roofs but not flat roofs, why??
Will I be better off sticking with the celotex or some other form of insulation rockwool etc.
Any experience on here of using the foil, is it effective??
Cheers
Concerns:
Cheers
