You mean an expanding foam which only clings to things that you want it to but which doesn't stick to your head? Oh, and products which cure instantly?
I do use expanding foam as a pre-fill but I always spray the surfaces with water to help adhesion. I have never used a foam that would not fall out of a hole that large if you try to do it in one hit.
