    Dismiss Notice
Foundation design - drain crossing at corner
Discussion in 'Building Regulations and Planning Permission' started by mfarrow, 13 Mar 2019.
  1. mfarrow
    mfarrow
    2 Nov 2009
    2,120
    Thanks Received:
    242
    Warwickshire
    Country:
    Hi
    I'm in the middle of a discussion with the BCO regarding the proposal to cross the corner of an extension where an existing 4" drain sits.
    The drain sits at a centreline of 530mm below ground level, so around 470mm above the bottom of any trench.
    I proposed a full fill foundation with 50mm compressible material around the drain:
    This was rejected by the BCO, who requested a 1m^2 pad foundation with lintels in a T-shape, which I felt would be too busy and confuse the build process. I therefore proposed the design below, i.e. increasing the ground bearing area in the corner, so the load would be spread equivalent to having a strip foundation built. Loads would be nicely spread around the drain using standard C20/GEN3 concrete:
    BCO has stated they believe this is fundamentally wrong, and has asked for the design as below:
    Personally, I don't see the point of an eccentric lump of concrete outboard of the corner, but I would value your opinion.
    Mike
  2. Sponsored Links
  3. noseall
    noseall
    2 Feb 2006
    35,386
    Thanks Received:
    2,230
    Staffordshire
    Country:
    Begs the question.....why on earth don't you extend that IC over to the corner, if the only reason for present positioning is that poxy kitchen gully?
    • Like Like x 1
  4. mfarrow
    mfarrow
    2 Nov 2009
    2,120
    Thanks Received:
    242
    Warwickshire
    Country:
    Good point, but I'm not sure I could lose the step in the IC, it was very close when installed originally (ie small block of wood under a 1.8m level to get level).
  5. tony1851
    tony1851
    23 Feb 2012
    9,272
    Thanks Received:
    1,389
    Manchester
    Country:
    Have you or the bco considered Ancon stainless steel ladder reinforcement in the bed joints of the first few courses above the concrete?
    This would turn the below-ground brick/blockwork into a beam capable of cantilevering the wall over the pipe; the distance the wall would project beyond the pipe does not look to be very much.
    https://www.ancon.co.uk/products/masonry-reinforcement/
  6. Ian H
    Ian H
    14 Sep 2010
    5,863
    Thanks Received:
    638
    Rochdale
    Country:
    You could probably loose the chamber on the right.
  7. ^woody^
    ^woody^
    3 Sep 2006
    27,134
    Thanks Received:
    3,389
    West Mids
    Country:
    Just have one manhole on the corner
  8. noseall
    noseall
    2 Feb 2006
    35,386
    Thanks Received:
    2,230
    Staffordshire
    Country:
    Fchuck me I've got an echo or two oo oo oo.
    • Like Like x 1
  9. Ian H
    Ian H
    14 Sep 2010
    5,863
    Thanks Received:
    638
    Rochdale
    Country:
    Oo oo
  10. Sponsored Links
  11. wessex101
    wessex101
    4 Jul 2013
    1,022
    Thanks Received:
    171
    Dorset
    Country:
    Imitation is the highest form of flattery.
  12. ^woody^
    ^woody^
    3 Sep 2006
    27,134
    Thanks Received:
    3,389
    West Mids
    Country:
    How does one extend a manhole? Does it need a bigger lid?
    • Like Like x 1
  13. Ian H
    Ian H
    14 Sep 2010
    5,863
    Thanks Received:
    638
    Rochdale
    Country:
    It possible but it’s an ass of a job
    • Like Like x 1
  14. noseall
    noseall
    2 Feb 2006
    35,386
    Thanks Received:
    2,230
    Staffordshire
    Country:
    That donkey knew wot I meant. I could be a designer me. I just need the correct helmet.
  15. ^woody^
    ^woody^
    3 Sep 2006
    27,134
    Thanks Received:
    3,389
    West Mids
    Country:
    Ee aww
  16. mfarrow
    mfarrow
    2 Nov 2009
    2,120
    Thanks Received:
    242
    Warwickshire
    Country:
    Just to close the thread, which I forgot to do, the Ancon solution was considered a "nice idea" but ultimately they needed calculations to justify it, so big old lump of concrete it is.
    On the "new chamber in corner" idea, yes this would be good except I know the falls in the sewer pipe are around 1:200, so this isn't practicable with a plastic manhole (where you get a step between side entry and exit) unless the builders can find a step-free one and have their wits very much about them when installing the inlet/outlet (and an even smaller block of wood on the level than I used originally).
    Or the pipe would need to be actually level, as opposed to practically level... if you catch my drift.
  17. Ian H
    Ian H
    14 Sep 2010
    5,863
    Thanks Received:
    638
    Rochdale
    Country:
    There are step free ones to go round a bend and with a single junction.
    • Thanks Thanks x 1
Loading...
Share This Page
