French cable designations
  • Thread starter Thread starter hi1
  • Start date Start date
hi1
4 May 2008
Gloucestershire
I have a thermostat going to a boiler, all destructions in French, the book has the cable labelled as L and S presumably L = live and S= neutral bearing in mind that in France the neutral is live I believe. Can anyone confirm this please
Maybe a false presumption
Instruction for a French machine's power connection
une borne de câble sous tension, une borne de ligne neutre et une borne de câble de mise à la terre.
borne = terminal
câble sous tension = LIVE
ligne neutre = Neutral
Thank you for that. So I could look at the cable going into the pcb and deduce what they are from the cable colour presuming that its wired up correctly which if you look at the central heating forum leads me onto the crux of the problem.
