- Joined
- 28 Dec 2023
- Messages
- 48
- Reaction score
- 1
- Country
hi, for my self-built garden room I've ordered a french door (1400x1990) with low profile aluminium threshold and a 150mm cill to sit below the aluminium frame. The reason for the low profile is this is going to be used as a woodwork space and the room being already elevated by 30cm off the ground seated on top of a concrete base, I thought it would be sensible to have minimal obstacles entering the room especially when carrying stuff in and out of the room. As for the cill, it is to make sure that water is drained outward. There is a overhang of 400mm at the front of the room so not so worried about water ingress. However the company said due to the Aluminium profile there are no drainage holes in the cill which surprised me.
Is it common to install low threshold ali on top of upvc cill? Can this set up lead to issues with water drainage and insulation?
Is the installation as straight forward as normal framed French doors? I can't find any videos demonstrating this particular installation, not even on the website where I purchased the door from.
Any thoughts would be helpful. Thanks, Shlomi
