Hi All,
Long time browser, first time poster. Hopefully I can contribute at some point rather than just ask. Now in our second Victorian house which we are renovating while we live there one room at a time!
I am going to replace the dining room window (which is in a bad way) with patio doors, which I have already bought. They are solid pine and double glazed. I have done a lot of reading on this so know about all of the building reg implications etc. The opening for the door is only about 200mm wider than the current window but I will obviously need to replace the lintel. Catnic recommended the CN71C as this is an external wall on a two storey house and I think the joists above run perpendicular to the wall.
My friend has a spare 152x89 section RSJ which I thought would probably be a suitable replacement. It is long enough to allow at least 150mm bearing at each end. What do you guys think? I would probably use some engineering bricks as a padstone but where would I install the lintel? The wall measures around 270mm in width so it should just be solid brick. Do I place the lintel right in the middle or towards the inside wall or is this RSJ simply not wide enough? Maybe I would need two of these or could use steel bearing plates to spread the load. The external wall is rendered so no problems with cosmetics on that front.
Any help would be greatly appreciated because I want to do a good job on this.
