I have Vokera Linea combo boiler which has recently startling giving error 01 (no ignition at hot water or heating).
The issue was occasional initially so I called gas safe engineer wet who serviced the boiler and said it should be fine. The. The problem appeared again after a month or so and I called another Gas Safe engineer who did same thing and assured me the boiler should be ok now.
However now the boiler has stared the same thing after couple of months. It has been pretty regular during Jan/Feb. Every time I open hot water tab the boiler doesn’t ignite. I have to switch off and switch on the boiler and then it works - sometime after 2/3 attempts.
I have small children in the house so conscious if it completely stops one day. Other concern is 2 Gas Safe engineers couldn’t fix the root cause so I am not sure if it is worth calling them again considering call out charges and service fee when the issue is not being fixed.
I wanted to take some expert advice and help from yourselves if there is anything I can do. I am normally pretty good in opening and fixing normal things (DIYs etc) but considering boilers are complicated machines I wanted to see if someone can provide any guidance / help.
Appreciate your time and help.
Many Thanks.
Many Thanks.
