    Dismiss Notice
Frog tape removes paint when removed?
Discussion in 'Decorating and Painting' started by Swell1, 14 May 2021.
  1. Swell1
    Swell1
    22 Mar 2021
    45
    Thanks Received:
    Country:
    Hello, every time we use masking tape or frog tape, when removing the tape they often remove small flakes of paint/plaster? Does all tape do this? Many thanks
  2. mattylad
    mattylad
    27 Apr 2008
    8,282
    Thanks Received:
    631
    Country:
    I had the same on my new walls, hence having to go round touching it up. :(
    I await the replies from those in the know as to why. (and if they say it's too soon to be painting, mine was left several weeks).
    • Thanks Thanks x 1
  3. Sponsored Links
  4. sparkwright
    sparkwright
    20 Aug 2009
    8,775
    Thanks Received:
    1,102
    Dorset
    Country:
    The YELLOW frog tape is the one that should do the least damage.
    What are you using?
    • Thanks Thanks x 1
  5. Notch7
    Notch7
    15 Sep 2017
    25,289
    Thanks Received:
    1,791
    S. Uplands
    Country:
    Sometimes the only way to avoid it is to remove the masking tape before the paint is dry.
    • Like Like x 2
    • Thanks Thanks x 1
  6. Sponsored Links
  7. sxturbo
    sxturbo
    12 Jan 2014
    4,038
    Thanks Received:
    582
    Essex
    Country:
    • Thanks Thanks x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
