if you cant be constructive then keep shelling your peanuts.
I am constructive. Your boiler/frost stat is not wired as it should be.
A standard froststat is a phase switch, and therefore should have no blue or black wire leading to it.
At the very least, that means the wrong cable has been used. There are stats like horstmann and I think some draytons that actually do need 230V supplied to them to work, and reversing polarity does not go down well with some boilers/controls.
Comments and feedback from people who have been through extensive training and have a valuable knowledge base are worth gold for people like me...
I am what you probably would call "corgi qualified" as well as "NIC qualified"
who do not have the depth understanding but have the power to reason and apply common sense.
Disconnecting mains power wires without looking where they actually went individually, is not what I would call common sense.
Trying to reconnect them without knowing how to test things to make sure that it is safe, is not very sensible either.
Remember with out people like me, people like you would not have a forum like this, you would have facebook...........
The section known as the combustion chamber is not even accessible for people like you, and........ a lot more interesting.
