Hi again,
Just had this boiler repaired after a week of no c/htg or hot water!
Heat exchanger replaced for 2nd time in 3yrs on an 11 year-old boiler along with a few other "bits & bobs".
Since completion of the repair at around 2-2:30pm this afternoon, the boiler has repeatedly refused to light after the boiler overheat protection has activated. This is due, I believe, to air in the system?
All the rads have been bled repeatedly (with the pump off) and each time the boiler cut-off needs to be re-set, the rads are checked again for air, so I'm quite happy that there is little (or no) air left in the radiators.
The only thing that hasn't been bled is the hot water tank (and I wouldn't know how to do this if this needs doing as I don't know where the bleed valve is if there is one).
So far, the boiler has tripped (if that is the correct word for this overheat protection) 9 times since 2:30 and the heating has been on since then.
Boiler thermostat was on "3", I've now turned it down to "2" (out of a range from 0 - 6).
EDIT: Overheat still tripped. Now set to 1 1/2. Here's hoping.
EDIT2: Radiators are too hot to grab and hold on to - ie over 60˚C. They aren't glowing mind you, just a bit hotter than "hand hot". Symptom that boiler is over specified (but then why hasn't it done this during the past 11 years)??
If I press the reset button, the boiler will relight straight away.
So, likely problem & possible remedies?
Thanks in advance.
Dave
Thanks in advance.
Dave
