Fuse board - EICR assessment
Properly installed and maintained metal ones are fine.
No matter how properly installed and maintained they may be, that doesn't alter the fact that having lots of earthed metal in close proximity to potentially live parts creates a hazard - particularly (given that this is a DIY forum) in relation to non-electricians who might sometimes be 'fiddling in CUs' without adequate knowledge and/or care. I would personally prefer not to possibly be reliant on paint to save my life!
As I often write, if it hasn't happened already I feel sure that it's only a matter of time before someone dies because a CU was ('unnecessarily') metal ... and, as I recently reminded people, the regulation requiring CUs to be 'non-combustible' (impossible though that is!) is plain daft, anyway, because it does not require any 'fire containment'.
I don't think that would be a guaranteed solution - we could well find some C&G 2391 'trainers' teaching that plastic CUs should be given C2s!
Since, having not been around this forum for long, you probably are unfamiliar with my personal views about what should be done about EICRs,, so see the very brief summary I've just posted in response to EFLI
Those are your personal views, mine are my professional views.
Edit: Trainers should all train to the same standards.
You could say the same about changing a wheel on your car after a puncture, or many other things that are "unsafe" because of people diying them.
Gas have the right idea by making it a prosecutable offence to interfere if you are not gassafe registered. The same principle should be applied to electrical work, but unfortunately it isn't.
Many domestic fuseboxes/CU's are installed in cupboards and surrounded by clothing and junk. There is more chance of controlling a fire with a metal cu over a plastic one.
But how many fires are started by CUs?
Never encountered one as yet
The quality of CUs has dropped since about 1990 - they are mainly very poor, encased by plastic or metal - the internal components are 2nd rate to say the very least
Neither have I, but this I found interesting.
To qualify that, not in a domestic situation, but I have seen a few in industrial which was where I worked. Luckily they were steel switchboards and db's which gave good containment.
Does that mean that you disagree with my views about EICRs, as summarised above?
"should" is an appropriate word. Don't forget that we are taking about issues in relation to which there is considerable variation in interpretation and views amongst professionals - so I'm not sure what your 'same standards' would be.
To a degree, yes.
The standard set by City and Guilds.
Trainers should all be working to the same guidelines and itinerary as they do with gassafe. Personal thoughts should not come into it. If the training and examination was all to be set to the same level and enforced the variation in interpretation would vastly be reduced.
You already saw the comment from @ericmark that he would be assessing to a standard from 2008 not 2018 with amendments which would cause massive confusion as the standard he would be using is so out of date.
As I wrote in a recent thread, it seems almost inconceivable that LFB are correct in claiming (in their article proclaiming the upcoming requirement for 'non-combustible' domestic CUs) that domestic fires originating in CUs increased 5-fold during the period 2009-2014. As I wrote, I can but presume that, for whatever reason, LFB became 5 times more likely to attribute fires to CUs during that period!
To a degree, yes.
So you wouldn't like to see strict regulation of who could (and could not) undertake EICRs?
Trainers should all be working to the same guidelines ...
But who's 'guidelines'? As I said, at present there are no mandatory 'rules' about the coding of EICRs and, whether you lioke it or not, the views of professionals, and of organisations, vary.
True - and he is a well-qualified 'professional' - but, not the least for the reason you give. probably should not be allowed to undertake EEICRs.
Yes, I would like to see it as I said, tightened up like gassafe.
City and Guilds (or whatever examining body was chosen) should set the standards along with the IET. As the IET publish the regs they should also have access to the appropriate examining body resource to ensure consistency throughout the trade. NICEIC, Elecsa etc should all have to conform to that standard or lose their licenses.
But like many others his qualifications are well out of date. Mine are reasonably close, I have 18th edition but not the latest. NICEIC used to insist that your qualifications were kept up to date to hold the title of Qualified Supervisor which I held for some years.
I was also MIET for about 15 years.
