    Dismiss Notice
Fused plug onto motion sensor security light
Discussion in 'Electrics UK' started by Graeme, 22 Dec 2019.
  1. Graeme
    Graeme
    23 Dec 2002
    268
    Thanks Received:
    6
    Glasgow
    Country:
    Received a 30 watt 200 volt motion sensor security light in the post, which has been shipped with bare cables at the end.
    It is not going direct to a switch, but to a plug which will be left on all the time.
    What size of amp fuse should I put inside the plug please?
  2. Sponsored Links
  3. flameport
    flameport
    10 Mar 2007
    9,817
    Thanks Received:
    1,962
    Poole, Dorset
    Country:
    3A or less.
    But if it's only 200 volts, it won't be of any use in the UK.
    • Thanks Thanks x 1
  4. Graeme
    Graeme
    23 Dec 2002
    268
    Thanks Received:
    6
    Glasgow
    Country:
    Thanks. I will put in a 3A fuse.
    Sorry, I meant 220 volts, 200 was the incandescent equivalent.
  5. winston1
    winston1
    11 Jan 2010
    6,987
    Thanks Received:
    531
    London
    Country:
    Still wrong though. The UK uses 240v.
  6. Astra99
    Astra99
    1 Feb 2011
    898
    Thanks Received:
    144
    Gloucestershire
    Country:
    Are you sure, Winston1? I am pretty sure that the whole of the EU standardised some years ago on 230V +10%/-6%. This would allow a maximum RMS voltage of 253 and a minimum of 217 (rounded up).
  7. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,456
    Thanks Received:
    2,116
    Oxfordshire
    Country:
    In Winstonland there is only one voltage.
  8. Risteard
    Risteard
    18 Jun 2010
    2,177
    Thanks Received:
    157
    Derry, Ireland
    Country:
    Ireland
    It uses 230V.
    The continent and the south of Ireland historically used 220V, which is also 230V now.
  9. winston1
    winston1
    11 Jan 2010
    6,987
    Thanks Received:
    531
    London
    Country:
    Indeed but if you measure the UK voltage it is (still) around 240v.
    But the fact of the matter is that something rated at 220v (probably from China) should not be used in the EU.
  10. Sponsored Links
  11. winston1
    winston1
    11 Jan 2010
    6,987
    Thanks Received:
    531
    London
    Country:
    NI historically used 230v.
    UK mainland historically used 240v and if you ever visit bring a meter and measure it now. Nothing's changed
  12. bernardgreen
    bernardgreen
    3 Nov 2006
    25,588
    Thanks Received:
    2,551
    Bedfordshire
    Country:
    Winston
    What would you say to a person living in the UK whose mains supply voltage is about 225 volts for most of the time. ?
    Should he complain to his DNO that he is not getting 240 volts which you claim is the voltage the UK operates on.
    If he took the supplier to court for breach of the supply contract would you be prepared to provide "expert witness" support to his claim in the court room. ?
  13. JohnD
    JohnD
    15 Nov 2005
    73,565
    Thanks Received:
    4,241
    Crossgates, Europe
    Country:
    Cook Islands
    Winston is not familiar with the term "GB."
  14. SUNRAY
    SUNRAY
    28 Jul 2009
    5,288
    Thanks Received:
    393
    Kent
    Country:
    WRONG
    WRONG
    So why didn't you say that in the first place, rather than make stupid statements?
  15. Risteard
    Risteard
    18 Jun 2010
    2,177
    Thanks Received:
    157
    Derry, Ireland
    Country:
    Ireland
    They all harmonised on 230V. But the tolerances are different. Britain and the Six Counties are +10%/-6%. Others are +6%/-10% and others are +/-10%.
  16. winston1
    winston1
    11 Jan 2010
    6,987
    Thanks Received:
    531
    London
    Country:
    Britain has more than six counties. Which ones are you referring to?
  17. winston1
    winston1
    11 Jan 2010
    6,987
    Thanks Received:
    531
    London
    Country:
    I suggest you get your meter calibrated. Usually the GB voltage measures around 245v, below 240 is extremely rare.
Loading...
Share This Page
