Fused Spur Timer - Timeguard FST11
21 Dec 2009
Kent
Hi Guys,
I am currently installing an electric heated towel rail in my bathroom. I have purchased one of these: http://www.tlc-direct.co.uk/Products/SMFST11.html to power it, because i want it to come on at certain times etc.
The instructions for which are here:
http://www.tlc-direct.co.uk/Technical/DataSheets/Smiths/FST11.pdf
I basically only want it to come on for a few hours in the morning and a few hours at night. Would i be correct with my wiring as below:
Live Supply from customer unit into 6
Neutral Supply form consumer unit into 5
Live from towel rail into 1
Neutral from towel rail into 4
Link with red or brown wire between 2 and 3
Earths into earth terminal
Your help is much appreciated guys.
Cheers
Ben
Just in case you're not aware, you also have Part P to contend with which will require notification to building control before you commence your work.
Gary,
This is replacing an existing radiator and using the same wiring which is there, but just putting the timer on instead, does this still require it?
Thank You
Ben
As long as the timer is not in the bathroom (which it's best not to be anyway) then I believe no notification is required.
The timer is in a completely different room.
Cheers
Ben
Under those circumstances then notification isn't required.
Regarding the timer, is it in the bathroom?
If it is then it would need to be outside of zones 0, 1 or 2.
Hi Gary,
It's in a seperate room with my shower isolater switch.
Ben
Sounds like you may be good to go then.
Did you see Bongos comment regarding RCD protection for the circuit?
Hi Guys,
Sorry for not replying, i am not sure whether or not my CU is RCD protected. I have a main trip as well as seperate trips for certain things etc. But not sure on the RCA thing.
Cheers
Ben
