- Joined
- 14 Dec 2021
- Messages
- 6
- Reaction score
- 0
- Country
I'm struggling to gain clarity from installers when discussing quotes for a new boiler. What I'm hearing is that they wont be able to tell whether my existing pipework will deliver an adequate gas flow until the install is underway - and at that point I potentially get a big additional bill to pull up laminate etc.
Current situation is a Greenstar 30si (Mk3) which has been measured as having a working pressure of 22mbar when running at max, dropping to 20mbar when the adjacent gas hob is running at max (all 5 rings - mixed fuel, electric ovens). There are no other gas appliances in the property. Water flow rate measured as 15l/min with 2 taps open.
I currently have 22mm pipework and understand that it would be common for 28mm pipework to be required to support my desired 35kW boiler. Considering either a Greenstar 8000 Life 35kW or a Viessman 100-W 35kW.
The measured working pressure would seem to my simple mind indicative of flow rate being adequate. Happy to be educated on why this isn't the case!
My plan B is a 32Cdi boiler which I'm advised should be a safe bet in terms of gas flow - but would like to understand if there is any way to get certainty (or 90%+ confidence) on a bigger boiler without getting halfway through the install process ?
Thanks in advance,
Craig
Thanks in advance,
Craig
