Hi my shower has sprung a leak! Where the hose connects to the cylinder inside the unit,not the actually hose but small connector at the base of the cylinder to which the hose connects,it will not tighten up just spins,is there a fix for this or is it goosed.Thanks.
Bit of a update,leak isnt from original thoughts,its from behind main heat control setting dial.I found out by switching shower on with cover removed electrics now wet through,turned off at mains,need replacement i think.
