I have a upvc back door with a gap between the bottom of the door and the sill below it. This should be fine, except that the sill doesn't seem to have been fitted properly and instead of being angled such that water drips off it onto the ground, its angled so water will flow back into the door. Any idea of the best (by which I mean easiest) way to fix this? I know I could just stick a bit of sealant in the gap, but was under the impression the gap served some kind of purpose (presumably to allow water to drip down the door, then flow off the sill)?
