Just installed new bath and unlike the last one, it wont fit up flush to the wall due to copper piping and the way the frame for the leg is positioned on bath.
Tha gap is roughly 30mm on longer side and 40mm on both the tap end and opposite. I could probably reposition to push the tap end more into the wall but would prefer the gap to be uniform all way around as any solution will be uniform aswell.
How do i fill in gap? Thinking of timber batterns onto the wall and putting the kind of PVC straight edging (you use for windows to seal to tiles) across the battern and onto the bath. Then if needed a normal bath trim to stop any water behind tile etc. OR is there something on the market especially designed for this problem.
