    Dismiss Notice
Gap Between Plyboards
Discussion in 'Decorating and Painting' started by Mark-UK, 2 Aug 2019.
  1. Mark-UK
    Mark-UK
    12 Apr 2016
    146
    Thanks Received:
    Country:
    Hope this is in the right forum.
    What's the best way to fill gaps between plyboards (other than saw straight in the first place)? They're on the ceiling and here and there they are about 1mm to 2mm wide.
    [​IMG]
    Nothing major but there's aluminium foil above them and it looks a bit unsightly.
    Any tips?
    Thanks.
  2. Sponsored Links
  3. opps
    opps
    16 Jun 2006
    4,751
    Thanks Received:
    754
    London
    Country:
    You have ply on the ceiling?
    Belt and braces- perhaps it might be best to apply plasterboard over the top.
    I cannot think of any filler that will not crack in time. A couple of hits with something like Toupret Fibracryl might suffice if you then apply lining paper.
    Alternatively, a MS polymer caulk such as CT1, and then lining paper.
    Unless noggins have been used, expect there to be a step where the sheets meet.
    • Thanks Thanks x 1
  4. Mark-UK
    Mark-UK
    12 Apr 2016
    146
    Thanks Received:
    Country:
    Thanks for the reply Opps.
    I'm starting to think it's not really a bother. I was hoping for a flush no gap seam everywhere and I have that for the most part. I think I'm just going to leave it as it is. It's just a shed after all. It's certainly nothing that needs doing.
  5. opps
    opps
    16 Jun 2006
    4,751
    Thanks Received:
    754
    London
    Country:
    Oh, it's a shed. I thought you had put ply on a room cailing.
  6. Mark-UK
    Mark-UK
    12 Apr 2016
    146
    Thanks Received:
    Country:
    No, just a shed. Although I will be spending a lot of time in it to do woodworking
  7. Sponsored Links
  8. conny
    conny
    30 Jun 2008
    13,562
    Thanks Received:
    721
    Suffolk
    Country:
    Mix up some of your wood shavings/sawdust with some PVA or clear silicone and use that as a filler?
    • Thanks Thanks x 1
  9. Mark-UK
    Mark-UK
    12 Apr 2016
    146
    Thanks Received:
    Country:
    That's a great idea - thank you
  10. sparkwright
    sparkwright
    20 Aug 2009
    8,379
    Thanks Received:
    1,044
    Dorset
    Country:
    If you don't want to risk cracking, fit battens over the joins.
  11. johny rryan
    johny rryan
    13 Aug 2019
    4
    Thanks Received:
    Country:
    India
    Using Sawdust and glue, one can easily cover the gaps in between ply boards. The method is commercial, the wood filler is more useful to make a change.
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
