I've just finished building the frame for my 3mx3m deck, layed on top of old patio. All the joists are in, and noggins in the 2 outer sections, remaining ones to be done tomorrow.
Anyway, while checking the level, i have noticed that there are quite a few places were the underside of the deck board doesn't touch the joist. In some places this is by as much as 5mm. This is despite all of the joists being flush with the outer frame.
I've searched old posts for this as I wanted to find out if this is normal, and just the result of having bowed wood (I did check the wood as I went along and it didn't seem too bad), however I am unable to find any mention of this - maybe because its such a basic question
Now, onto a solution, does the following make sense:
1) anywhere there is a gap insert some shims to fill it, from old offcuts. Also give the shims a quick coat of preserver.
2) lay 4 boards and shims at a time - before fixing check that the level looks ok in both directions.
3) if all looks ok fix boards, then do next 4
Any advice on this would be much appreciated.
Cheers
Cheers
