Hi, hope you dont mind me asking for advice on my first post. I have almost completed building my detached garage, everything apart from tiling the roof is done. Garage measures 6.5x6.5m is a double with two openings, with a pillar in center. I have two 6x4 concrete lintels over each entrance with 6"load bearing. Problem is, i used a piece of 2" timber bedded on top of the lintel for packing to close the gap between lintel and wall plate, so effectively has 4" of wall plate above lintel which will be supporting some rafters. Building control says there needs to be a row of bricks above lintel for the wall plate to sit on, but there was no room for full bricks do to the hight of garage door, i cannot see any gain by using bricks above a lintel but im sure i will be corrected
If this is the case could anyone suggest a way of overcoming this. The garage is single storey with a 24 degree trussed hip roof, building control admits there is not much load there. Next problem, i built the garage single skin from concrete blocks, but building control are saying i need to build another skin on the inside due to its size. I over did it on the piers at just over 2m centres (limit is 3m) and all my pillars are correct. Apart from the extra hassle and cost i would rather keep it single as i will loose some space inside. Any thoughts on this. Many thanks.
