After sorting the drainage at the front of the house (as per earlier thread), I want to knock through and convert the garage into an open living space. I'm hoping to do most of the work myself but will need some help along the way from you guys I'm sure!
First question ... It's a single skin outside wall which has a small amount of water ingress since the outside ground is at a slightly higher level. Will I need to build a second skin with cavity or could I just tank the wall, insulate it and cover with platerboard on a stud frame?
The gas and electric meters are in the garage. I may need to arrange for these to be moved to provide space for a door into the house. Expensive?
What would you suggest for the flooring?
Many thanks!
Many thanks!
