Hey everyone, long time lurker first time poster.
Looking to refurb my garage for as little as possible so going to do full DIY refurb on it. I'll give a brief run down then ask some questions.
Looking to replace the old asbesto/cement roof, by replacing with a flat roof. The approach I'm taking is to take off coping stones, bed some wall plates on each wall, strap them also and then attach/sit the joists from one wall plate to another. Use firrings to get the required slope then osb and probably just a 2-layer felt system for now.
My plan however is to get 4.8m lengths of wood and leave the excess overhanging into my garden so I can then build a wooden workshop on the side of the garage so they share the same roof. Once the workshop is built the plan would be to take out a bunch of the wall with the correct rsj or lintels to create a bigger work space.
Excuse the mess of the courtyard/side garden I've just ripped up a decking, junk to go to skip that there is no room in the garage for and the plan is to sort it this year (pull up all the slabs etc).
I suppose my main questions are should I possibly look at beefing up the roof joists, just in case I decide to remove all of the side wall and use the new workshop wall to take the load of the joists or keep it simple and stick to my original plan?
When I do the flat roof should I leave the front of the garage as a wall with the coping stones and start the roof right after that kind of the way it is already? Or should I remove the coping stones and start my first joist there?
I thought I had lots of questions but can't remember anything else for now. Oh and the plan is to get one of the golfs inside at a time to finish them off but I own too much crap and garage is tiny hence wanting to gain some space and headroom so I can put shelfing up higher.
Oh I'm also getting a new roller shutter door fitted tomorrow so I can use the wall space at the front of the garage too.
Thanks for any advice or ideas to make this a reality.
