What exactly is in the 'house fuse board' and how is the garage supply connected to it? (Pictures are better than descriptions)My detached garage electricity supply runs off of my house fuse board
Oh no don't presume or assume anything round these partsPresuming 4. What I'm not too sure about are the different trips switches.
not sure what you mean! You can have it on the garage socket circuit and have it on an internal isolator to power off.I want the outside socket on its own switch do I can't turn it off then not in use.
Basically I'm unsure which MCBs I need for lighting and socket rings. I'm gin to get a 4 or even 6 way consumer unit and just blank the spares. I want the outside socket on its own switch do I can't turn it off then not in use.
Any suggestions on what amp MCBs I need?
Cheeky bugger have you not read schedule 4?Someones going to say it eventually - so I might as well
This work is notifiable to your local Building Control.
