I'm building a 4.8m x 2.8m (ideally) garden room and need some advice on the base / subfloor and possibility of overhang on the floor joists.
As you can see in the image, I've got a concrete slab (not insulated) that I was going to sit the 3x2 treated joists directly on with DPC underneath each length for extra protection against moisture from the concrete.
I would then put 40mm insulation between these joists, supported so there was an air gap underneath. OSB then flooring on top of this. I cannot find much about this sort of structure, but have been advised it's fine. I can't have much more height as trying to keep headroom in 2.5m max limit.
As for the overhang, the concrete was built at 2.4m but now want the room 2.7, so looking up allowances for the 3x2 joists and spread every 400mm the overhang should be ok for 200mm either side. Obviously we would clad lower than the concrete for rain protection.
is this ok, firstly for the floor joists directly on concrete and also the overhang? The roof seems to be standard structure but have included on there incase.
thanks in advance.
thanks in advance.
