We want to lay a concrete shed base and extend it into a bit of a path. It would end up approx. flag shaped i.e. a rectangle with a longer thinner section coming off as the path. A friend suggested making a wooden frame, filling with some kind of dry mix, levelling & compacting then spraying with water. Something he had done in his garden.
Can any one help fill in the fine details?
Would I need a hardcore base - if so, what depth? or
Would sand be OK as the base - if so, what depth?
What depth of dry mix would I need to allow for?
Can you buy pre-mixed dry mix or what do I mix together?
How do you work out how much of everything to buy?
If I know depths I can work out the volumes of things, but sand & cement come in kilos/tonnes not cubic metres!
Any other advice welcome!
OonaghG
OonaghG
