Hi all
I'm just starting a diy garden room build and cannot find a definitive answer to this anywhere. The base will be made from treated 4x3 timber and will sit 2" off the ground on 9 concrete blocks. I believe the easiest way to insulate this would be to jam in some foil backed insulation between the joists. The question is, how likely are rodents going to start chewing through the underside of the insulation? What can I do to mitigate this? I was thinking of dropping in some 11mm OSB panels prior to the insulation but feels like a waste of time and money.
What do you think?
Many thanks
Chris
What do you think?
Many thanks
Chris
