gardtec 360
23 Mar 2016
I have just removed the door sensors on my Gardtec 360 alarm system to replace a front door and find that they no longr work. Any ideas how I fix this please.
I find your question a bit odd. If you remove the sensors from an alarm system, it won't work. What did you think would happen? You need to put them back on the new door.
When you removed the sensor did you write down the colours ?
Are they surface contacts or flush ?
If you have another door contact on you system go and see how that is wired.
If the new door is upvc then the contacts need to be no more than 6mm apart for a surface contact.Do not fit a flush contact
