GardTec Eurosec CPX System - It's a worry
31 Oct 2010
West Midlands
Hi
I wonder if anyone can help. From time to time when I come home (with the alarm set) I put in the user code but the system doesn't do anything - so does not unset itself. I then put in the code again - still nothing, then again - still nothing. Eventually the system goes to ALARM then it will accept the code - I then say Yes and put the code in again and the system it unset.
This is worrying - I am always worried that the system may not accept the code when it goes to alarm and then I don't know what I would do.
Any help or ideas would be appreciated.
Stewart
It is programmed to DD243 Keypad locked on entry.
If this is a policed system use the fob provided.
If not desleect DD243 options.
Ahh, never thought this could do 243, always thought eurosec was like shed alarm :?
That'll teach me to check the manual lappy  8)
Sorry is this answering my query? Please explain. Why is it sometimes ok when I enter and sometimes I have a problem?
Stewart
Ok, how are you setting and unsetting the system? code or tag?
if its via code, then you could have a sticky keypad or a faulty one.
It just the code, if I made a mistake in putting in the code will putting it in again help? Is there a way of clearing and starting again?
There is no need to clear & start again. If you make a mistake, press NO and re-enter your code.
If you have the user guide for the system, i would suggest you change the code for something your not going to make mistakes with.
Also suggest you have the system serviced by the installing co.
