Hi all,
I want to run some power to my shed from the house and am would like to know if what I have in mind is sensible / will comply with the regs.
I would like to run 25 m of SWA to my shed from the house - where it will connect to a weather proof CU (in the shed). In the house, I want to connect the SWA to a fixed spur using an RCD.
The reason for using a spur is that my main CU (in the house) is full, though, I have one breaker that runs an existing outdoor light, so I guess I could hook in there if necessary.
Then, I want to run 1 RCD protected double socket off the CU in the shed. On this circuit, I also want to run some standing lights on a deck that I am currently building.
Also from the CU in the shed, I want to run a second circuit for some small low-voltage deck lights.
Do I need to use SWA to feed the deck lights, even though the cable is under the deck ?
Also, can anybody give me any advice on certification. Is it ok to put covers on / finish the deck before certification ? Also, does anybody have any idea of how much certification costs ?
Anyway, thanks very much - if somebody could give me some advice on what I have in mind, I would appreciate it.
Many thanks,
James
Many thanks,
James
