The Real Rescues TV program ( episode 21 (?) on BBC 1 11th April 2013 featured a couple of terrraced houses blown apart by gas explosions seconds after fire brigade crews came out of the houses having extinguished kitchen fires in two houses.
The cause given by the officer in charges was that metal theft had removed "one of the electicity supply cables leaving the buildings live" and went on to say that as a result large currents had gone to ground via the gas pipes. The anaconda pipes to the gas meters had melted releasing gas.
I assume the metal thiefs had taken out the "safe" neutral supplying the terrace and neutral currents had gone via the bonding to to the gas meter and into the ground via metallic gas supply lines.
