Gas Hob Help
13 Nov 2007
Northamptonshire
My family were given this some time ago, Now there kitchen is complete, they want to fit it.
Here are the details
http://64.233.183.104/search?q=cach...8/+hygena+ahy1120+KW&hl=en&ct=clnk&cd=1&gl=uk
As its only gas, is it simply a case of putting a plug top on with a 3a fuse (the stats on the plate underneath say 3amp.. But i noticed the Max output is 7.2kW. I was not sure after i saw that.)
The main cooker feed is fed from the CU with a 32amp breaker, that is taken from the oven. The specs for the oven are 4.7kW.
Dont think the 7 kw refers to the electric power
Looks like it just needs a supply fused at 5 amp from a FCU (spur) or a plugtop,for the ignition
The oven supply may be able to be adapted to incorperate that, so the Existing oven switch isolates the hob as well
