Supply for gas hob and electric oven
27 Mar 2007
Surrey
I will be installing a gas hob with electric oven underneath. I have a cooker switch wired in 6mm from 32A MCB and want to use this dedicated circuit to reduce the load on the ring.
Since the oven is rated at 13A (comes with a plug), and the hob at 3A, is it better to:
1) Run 6mm cable from the switched side of the cooker switch to 2 FCU's fused at 13A and 3A instead of a cooker outlet, and wire the oven and hob flexes into the FCU's.
2) Power the hob off a separate FCU on the ring circuit, and power the oven from an FCU or normal socket connected to the switched side of the cooker switch.
Both seem OK to me, but was wondering if there was a standard, best practice way to wire these appliances.
Go for (1) and wire from the load side of thge cooker switch to fs 1 13a and then on to fs2 3a.
2.5 TE will cover the loads, no need for 6mm which is a PITA to terminate.
Agreed Chri5! Yes 6mm is a s0d to terminate without much swearing.
Thanks for the reply.
