I bought a house last year and discovered the boiler is a 2015 Ideal Logic + 30KW Combi that has it gas feed on a 15mm pipe.
The distance between the gas metre and the boiler is around 1.3m pipe run, possibly less as it is installed adjacent to the wall of the gas meter.
There are 3 elbows on the pipe run. The first 300mm ( double wall plus cavity ) are on 22mm pipe with a T that is reduced to 15mm for the rest of the distance and another 2 elbows. So the full length of the 15mm is a bit less than a metre.
As I am refurbishing the kitchen should I upgrade to a 22mm pipe as otherwise I will have to rip some floor units in order to have access if there is a need for a bigger size pipe in the future.
