Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
how can i check internal gas pressure because my boiler just fires up for 20 sec then cuts off then turn the tap off and back on boiler fires up and goes off again same on CH help please
thank you for reply I have worcester 24i fitted about 2 yrs ago worked fine now when turn the hot water tap on fires up but cuts off after 20 sec while the water is still running, does the same on CH i replaced the pcb ,air p switch,thermistors,but problem is the same,pump runs elec there thanks
