I have worcester 24i fitted about 2 yrs ago worked fine now when turn the hot water tap on fires up but cuts off after 20 sec while the water is still running, does the same on CH i replaced the pcb ,air p switch,thermistors,but problem is the same,pump runs elec there.
Now i changed the boiler but the problem is the same how can this happend is it something to do with the gas supply?Is it the low gas pressure?
