    Dismiss Notice
Geberit or Grohe concealed cisterns for our new build?
Discussion in 'Plumbing and Central Heating' started by RigidRaider, 5 Apr 2020.
  1. RigidRaider
    RigidRaider
    9 Aug 2006
    1,727
    Thanks Received:
    68
    Lancashire
    Country:
    I've just discovered yet another leaking bottom flush pipe seal on a concealed Geberit cistern, which is especially annoying as we are about to market this house and I think I may have to break through the plasterboard behind the pan to replace it. Luckily I bought spares last time it happened in the downstairs WC.
    Google says this and the blistered silicon flush piston seal is common and it also says Grohe pans suffer the blistered flush seal problem (easily replaced) but it doesn't mention the leaky flush pipe seal with Grohe cisterns. Is the Grohe flush pipe seal better designed than the Geberit seal? Which is the better cistern?
  2. Sponsored Links
  3. Elkato531
    Elkato531
    22 Jul 2009
    1,001
    Thanks Received:
    235
    Sussex
    Country:
    • Thanks Thanks x 1
  4. duffin
    duffin
    19 Oct 2008
    145
    Thanks Received:
    26
    Warwickshire
    Country:
    For some reason, geberit grey seals blister, but the newer clear ones dont. Go for the fluidmaster one as previous post.
    • Thanks Thanks x 1
  5. RigidRaider
    RigidRaider
    9 Aug 2006
    1,727
    Thanks Received:
    68
    Lancashire
    Country:
    Bad news.... the new clear ones do blister. I've just changed one.
  6. ReJect
    ReJect
    19 Oct 2019
    310
    Thanks Received:
    60
    Country:
    That is disappointing! First I heard that the new Geberit silicone rubber seals blister. At least they are easy to replace.
    The older type rubber seals blister because they are a sponge type rubber and absorb water.
    If you simply use a pin to burst all the wee blisters, the washer will seal again fully and do as a temporary fix.
  7. JohnD
    JohnD
    15 Nov 2005
    69,921
    Thanks Received:
    3,943
    Crossgates
    Country:
    Cook Islands
    boxed-in plumbing apparatus is a source of much unhappiness.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
